TK44
Sep 17, 2022Aspirant
Xbox Series X keeps dropping
Just bought this router and once I set everything up, I fired up the Xbox Series X and it does this thing where it'll connect via Ethernet cable for a second and then it'll disconnect. I've tried ch...
Sep 17, 2022Guru - Experienced User
And sometimes where the firmware on it was several generations out of date and you go all the way to the latest, old (default) settings can cause issues. so its worth a shot.
TK44
I have the latest firmware. I jumped from a lifetime linksys user to this and have had nothing but issues.
I'm at the of my wits eith this thingvas it now doesn't see other computers hard wired in. The app completely SUCKS can't even do advanced troubleshooting through the app. .
NETGEAR fix your systems.
- plemansSep 17, 2022Guru - Experienced User
1. We're not netgear. We're the community support forum where members of the public help out.
2. you can contact support. Maybe you did get a bad device. It does happen.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
