Julian_Jay
Feb 03, 2023Tutor
Xbox Speeds slow
Good evening !
I’ve exactly the same problem. I’ve 800Mbit speed on my IPad, Mac, Apple TV but unfortunately 40Mbit on Xbox_X. I own a brand new Night Hawk RX200 and I love it.
I have tri...
- Feb 04, 2023Julian_Jay just to clarify, which router do you have exactly?
Netduma-Fraser
Feb 04, 2023NetDuma Partner
Julian_Jay
Feb 04, 2023Tutor
Good evening!
Apologise for the miss spelling of the product. I’ll make an another effort to correcting the mistake..
The model is RAX 200 Night Hawk. What a connectivity and speed! I forgot to mention the marvellous futuristic design.
My extensive research showers there is a software issue with Xbox_X_series_X’s. I don’t think the AC protocol woking properly. It’s not able to handle the 4800 MHz range and needs an update. Almost all of owners are showing imitate concerns regarding the bug which limites the bandwidth. I would like to add many have tried wired connection with cat5.e.6.8 with similar results.
The mystery shall come to light and reveal itself with some debugging.
The “NIGHT HAWK” functions flawlessly.
Many thanks indeed for the outstanding product.
- Netduma-FraserFeb 04, 2023NetDuma Partner
Ahh, you'll want to make a post here instead: https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/bd-p/en-home-routers-nighthawk-wifi-ax6 as this section is for the Nighthawk Pro Gaming range of routers
