Golfer2016's avatar
Golfer2016
Follower
Sep 11, 2020
Xbox will not pick up 5G from Nighthawk RX50
I need some help. My Xbox One X will not pick up my 5G wifi signal. My computer that is right next to it is connected to the 5G. However, I am picking up other 5G networks from neighbors houses.
1 Reply
  • plemans's avatar
    Is your xbox up to date on its firmware/software?
    Reason why is older drives have issues seeing the AX wireless 5ghz signal.
    options?
    1. make sure xbox is updated.
    2. check with microsoft on software/firmware for the xbox
    3. disable AX on the router.
