Runts
Jul 20, 2021Follower
XR1000-Netgear Armor
Hello peeps, I'm considering the netgear armor subscription. I have two questions. First off, is it worth the price? Secondly, if I upgrade my router again down the road, will the subscription be...
Jul 20, 2021Guru - Experienced User
Is it worth it?
Depends on your home and how computer/tech savvy people are. I use a base antivirus/malware suite but thats in. at my parents, I have a fairly extensive setup as they don't know what not to click on.
Is it transferable? Yes you can move it from one to the next. You have to contact support to do so but it is doable.
