Gooner21
Sep 26, 2022Aspirant
Access Control blocking 1 device and unable to change to allow
Hi Guys Just out of the blue, my work laptop is being blocked by Access Control on my Orbi router (RBR50) I've tried both options of slecting the device and choosing "Allow" and clicking the r...
- Dec 17, 2023
This is an older thread, but hopefully will help someone. After several different approaches, I believe I've finally figured out this issue. Turns out, the older Genie software has an Allowed Device quantity limit, which includes both connected and unconnected devices. Once you reach that limit, the software will not Allow any other devices (ie, added to that list). Inane in today's age of wireless everything, but (almost) understandable when Genie was written.
The work-around solution is to clear out any outdated devices from your Unconnected listings - a list which simply grows and gets forgotten throughout the life of the router. Clear up 5 entries, gain 5 more entries for the Allow list. If you reach a point where you hit another "Blocked" device that can't flip over to "Allowed," you'll need to delete some more (hopefully) outdated devices. If you run out of Unconnected Devices to delete from the list and are still facing this issue, it's a sign that you need a newer router.
I've since swapped to a newer device that does not run on Genie. But, for those that might still need these routers, I hope this helps resolve the issue.
ekhalil
Sep 28, 2022Master
If you check the Access Control and also mark device and click Allow and then Apply. Then Unckeck the Access Control and click Apply.
Will this change anything?
Gooner21
Sep 28, 2022Aspirant
Tried both options
Tried the check and Allow "and" clicking on the device, going to the next page and changing the drop down to "allow"
Both do not change once the page refreshes, the device is stuck on "BLOCKED"
Also, "If you check the Access Control and also mark device and click Allow and then Apply." cant be done, as soon as I check the device and click allow the page refreshes (can't then click apply)
- CrimpOnSep 28, 2022Guru - Experienced User
Sorry for being so "slow" today. That Blocked device appears in the top table.
Unless I am mistaken, the top table is of devices that are currently connected to the system.
Can you please:
- Power off the TABLET
- Refresh the Access Control page until the TABLET moves to the very bottom table:
"View list of blocked devices not currently connected to the network"
Orbi's do not update status pages very quickly. May take more than five minutes. - Mark the device and Click Remove from the List
Does this make any sense? Not really. There are clearly marked boxes for "Allow" and "Block". They should damn well work. There is also a box for "Edit" which (on my router) brings up a drop-down menu with options for Allow and Block. Have you tried Edit?
- Gooner21Sep 28, 2022Aspirant
Yes I have done that, I actually have 2 Surface Pros (1 work 1 personal)
I've tried deleting all devices on the "not connected" list but as soon as it powers on I get the "this page is being blocked by access control" message for any website
I have a feeling no-one will know why this is happening and I will have no option than to factory reset and start again (and not knowing if this is just going to happen again as soon as I re-connect it) 😞
Are these Surface tablets configured to randomize MAC address or to use the hardware MAC address?
Can you force a similar issue with any other device?
Just stock standard like any laptop, I have been using both on this network since I set the Orbi's up about 7 or 8 months ago, its only started happening in the last week
- ekhalilSep 29, 2022MasterIn my Orbi systems I have SPC (Smart Parental Control) active by default and I can’t find a way to disable it.
Basically if you Orbi is registered the you will have SPC activated and it’s up to you later to buy Premium services or just keep the basic SPC which is really just the simple Access Control (where you will just see list of all your devices (you will though see users instead of devices) and the option to allow internet or pause internet.
That makes me wondering why you don’t see SPC section in your Orbi app. Did you ever got a question whether you want activate SPC? Is you Orbi registered?
I believe the issue you’re seeing is related to a conflict between access control and SPC. - Gooner21Sep 29, 2022Aspirant
No I dont have Parental controls on,. That is only part of the Premium which I have never paid for
- csmba15Mar 04, 2023Tutor
same problem but in my case it blocs my roomba irobot. click the allow action does nothing. I can only use roomba if I disable access control .
if anyone found a solution, please post. netgear supports said to do factory reset.. haven't tried it yet and it is a pain . I am on the latest firmware
