Gooner21
Sep 26, 2022Aspirant
Access Control blocking 1 device and unable to change to allow
Hi Guys Just out of the blue, my work laptop is being blocked by Access Control on my Orbi router (RBR50) I've tried both options of slecting the device and choosing "Allow" and clicking the r...
- Dec 17, 2023
This is an older thread, but hopefully will help someone. After several different approaches, I believe I've finally figured out this issue. Turns out, the older Genie software has an Allowed Device quantity limit, which includes both connected and unconnected devices. Once you reach that limit, the software will not Allow any other devices (ie, added to that list). Inane in today's age of wireless everything, but (almost) understandable when Genie was written.
The work-around solution is to clear out any outdated devices from your Unconnected listings - a list which simply grows and gets forgotten throughout the life of the router. Clear up 5 entries, gain 5 more entries for the Allow list. If you reach a point where you hit another "Blocked" device that can't flip over to "Allowed," you'll need to delete some more (hopefully) outdated devices. If you run out of Unconnected Devices to delete from the list and are still facing this issue, it's a sign that you need a newer router.
I've since swapped to a newer device that does not run on Genie. But, for those that might still need these routers, I hope this helps resolve the issue.
Lumi_01
Dec 17, 2023Initiate
- LAKingsGeekDec 19, 2023Aspirant
I have this same problem with a RBT750 that I bought for my mother. When i first set it up I did not realize Access Control was turned on and right off the bat her MBP and Vizio TV were blocked. Considering these were among the first 3 devices connected to the router it seems unlikely that this is caused by some old legacy limit on devices allowed by the genie software.
I was able to turn Access Control off but about a month later i got panicked messages from my mom that she couldn't watch her Prime shows or connect to the internet. I assume a firmware update turned it back on. I tried allowing the devices under Access Control but they were immediately blocked again. Even turning off Access Control didn't seem to work at first but I eventually got it working after trying a few times.
This is unacceptable behavior for a router that's supposed to be easy to set up and use with the App. The fact that I can't control Access Control within the app is even more annoying. My elderly mother isn't going to understand how to use the web interface.
Has there been any official response for this issue from Netgear? It seems like this has been a problem for years. I'm not sure if I'll be able to return it so I might have to sell it and take a hit.
