Floridaplur
Apr 05, 2025Follower
Accessing parental controls from MacBook? Also, android app crashes.
After the android app decided it no longer will allow us to access parental controls without crashing, I took to my M4 MacBook Air. The iOS app is listed as not compatible, and the web based log in d...
Apr 07, 2025Guru - Experienced User
All SPC controls are now access thru the Nighthawk app only. This app only works and is supported on Apple or Android Phones or pads.
