NickM02
Feb 19, 2023Aspirant
AX2400 STUCK ON PAUSE PLEASE HELP! NO SUPPORT FROM NETGEAR!!!
I briefly paused my router and now my phone is blocked from using the app, ive tried using the website but it seems like netgear took away router control from pc, i need it remotely unpaused which i ...
- Feb 20, 2023Zo I ended up fixing the issue, but the solution is still unknown, netgear has a nighthawk app that gives you access to parental controls, you have the option to enable and disable devices, I temporarily paused the network on the app and was then bricked out from the router, I had to factory reset the router twice before it was able to catch a internet connection, again I have it working now but the option to pause/unpause is broken and bricks the AX2400
Kitsap
Feb 19, 2023Master
NickM02 wrote:I briefly paused my router and now my phone is blocked from using the app, ive tried using the website but it seems like netgear took away router control from pc, i need it remotely unpaused which i dont have the option to do and ive found 0 ways to contact support
Just a guess, you might have shut the Wi-Fi radios off with the manual switch. The second LED up from the bottom is a combination indicator/switch. Push and hold it for a few seconds then release. The radios should come back on.
- michaelkenwardFeb 20, 2023Guru - Experienced User
Another guess – as microchip8 says, the origin al description doesn't make sense – perhaps NickM02 "paused" a connected device in the Nighthawk app.
We can all keep guessing until we have a description of what actually happened.
- NickM02Feb 20, 2023AspirantZo I ended up fixing the issue, but the solution is still unknown, netgear has a nighthawk app that gives you access to parental controls, you have the option to enable and disable devices, I temporarily paused the network on the app and was then bricked out from the router, I had to factory reset the router twice before it was able to catch a internet connection, again I have it working now but the option to pause/unpause is broken and bricks the AX2400
NickM02 wrote:
.....the option to pause/unpause is broken and bricks the AX2400Not really. Or we would have seen plenty of complaints here.
You just have to know what you are doing.
If you have problems with Parental Controls in future, try here:
NETGEAR Smart Home Parental Controls - NETGEAR Communities
