NickM02
Feb 19, 2023Aspirant
AX2400 STUCK ON PAUSE PLEASE HELP! NO SUPPORT FROM NETGEAR!!!
I briefly paused my router and now my phone is blocked from using the app, ive tried using the website but it seems like netgear took away router control from pc, i need it remotely unpaused which i ...
- Feb 20, 2023Zo I ended up fixing the issue, but the solution is still unknown, netgear has a nighthawk app that gives you access to parental controls, you have the option to enable and disable devices, I temporarily paused the network on the app and was then bricked out from the router, I had to factory reset the router twice before it was able to catch a internet connection, again I have it working now but the option to pause/unpause is broken and bricks the AX2400
michaelkenward
Feb 20, 2023Guru - Experienced User
Another guess – as microchip8 says, the origin al description doesn't make sense – perhaps NickM02 "paused" a connected device in the Nighthawk app.
We can all keep guessing until we have a description of what actually happened.
NickM02
Feb 20, 2023Aspirant
- michaelkenwardFeb 20, 2023Guru - Experienced User
NickM02 wrote:
.....the option to pause/unpause is broken and bricks the AX2400Not really. Or we would have seen plenty of complaints here.
You just have to know what you are doing.
If you have problems with Parental Controls in future, try here:
NETGEAR Smart Home Parental Controls - NETGEAR Communities
- NickM02Feb 20, 2023AspirantI have experience in IT, Nothing was wrong setup wise, my guess is after pausing it , it trapped itself in a internet boot loop, or maybe an issue with the newest firmware, currently I'm on factory settings and it's working great, the newest firmware locks me out
- FURRYe38Feb 20, 2023Guru - Experienced User
What model# is this system? AX2400 is not a model #.
What specific FW version is loaded on the system?
