Jwouter
Oct 30, 2022Aspirant
Cant pay for this service
Good day, I have a call with Netgear for almost two weeks. I used the trail for smart home parental controls. now I would like to buy it but I can’t. I can’t select the tick box accepting th...
- Jan 03, 2023
Yes after a number of escalations it was fixed by NETGEAR,
problem is definitely on their side , so not much you can do except escalate until the request debug data from your device…..
Sulphate9402
Jan 02, 2023Guide
Were you able to get it fixed?
- FURRYe38Jan 03, 2023Guru - Experienced User
- JwouterJan 03, 2023Aspirant
- Sulphate9402Jan 03, 2023Guide
I've been trying to for the past 2 months but they just keep going around in circles.
Anyways I've found the perfect solution. It is to buy a Firewalla router and setup the Orbi routers as access points.
Firewalla has a much better parental controls software and does not even require a subscription. Not to mention all the other features it includes that Orbi does not have.
I tried giving my money to Netgear but they simply would not take it.
