Stege
Sep 11, 2022Tutor
Cant unlock premium SPC future on RBR50
Hallo I can´t unlock the premium future of SPC (Mytime) on my RBR50 router My trial worked perfect but the trial period is closed and when i tap the unlock premium ind the android app there ...
Sep 11, 2022Guru - Experienced User
Stege
Sep 11, 2022Tutor
All should be okay
Country supportet - Denmark
Latest firmware - v2.7.4.24
Latest orbi app
- FURRYe38Sep 12, 2022Guru - Experienced User
Have you powered OFF the ISP modem, router and your mobile device for 1 minute then back ON and see if the NH Circle app can connect to the router?
- StegeSep 12, 2022Tutor
Hey
The orbi rbr50 router is connected to provider "FASTSPEED" in Denmark with a Sagem Fast 3890V3 for coax signal
I have tryed to turn of power on the Orbi royter and the Sagem unit
I have also tryed to start from scratch
Nothing has fixet it.
- FURRYe38Sep 14, 2022Guru - Experienced User
Your ISP modem has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
