Stege
Sep 11, 2022Tutor
Cant unlock premium SPC future on RBR50
Hallo I can´t unlock the premium future of SPC (Mytime) on my RBR50 router My trial worked perfect but the trial period is closed and when i tap the unlock premium ind the android app there ...
Stege
Sep 11, 2022Tutor
All should be okay
Country supportet - Denmark
Latest firmware - v2.7.4.24
Latest orbi app
Sep 12, 2022Guru - Experienced User
Have you powered OFF the ISP modem, router and your mobile device for 1 minute then back ON and see if the NH Circle app can connect to the router?
- StegeSep 12, 2022Tutor
Hey
The orbi rbr50 router is connected to provider "FASTSPEED" in Denmark with a Sagem Fast 3890V3 for coax signal
I have tryed to turn of power on the Orbi royter and the Sagem unit
I have also tryed to start from scratch
Nothing has fixet it.
- FURRYe38Sep 14, 2022Guru - Experienced User
Your ISP modem has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode- StegeOct 08, 2022TutorHey
Router is a sagemcom coax cable modem and router
Isp is 'fastspeed' in denmark
Sagemcom is in Bridge mode and wifi off
Orbi router rbr50 is factory reset and latest firmware installed.
Orbi has static ip assigned.
Still not working.
