KCPGS
Jan 27, 2024Follower
CBR750 and parental controls
I'm using my CBR750 as our modem and router. Netgear says that I should be able to use the parental controls, but the tile in the Orbi app doesn't show up. The Orbi is in router mode (which I underst...
KevinLiT
Jan 30, 2024NETGEAR Moderator
Hello KCPGS ,
Welcome to the NETGEAR Community!
I understand that you are unable to locate the SMART Parental control feature tile on your Orbi app. Please ensure that the device is registered and you are using the same email for your Orbi app as the email you are using to purchase the SMART parental controls subscription. This could also occur if your account is registered in a country where SMART Parental Controls are not available.
For more information on reason Why you do not see the SPC tile on your Orbi app please navigate to the link below:
Best,
Kevin
Community Team
