KCPGS
Jan 27, 2024Follower
CBR750 and parental controls
I'm using my CBR750 as our modem and router. Netgear says that I should be able to use the parental controls, but the tile in the Orbi app doesn't show up. The Orbi is in router mode (which I underst...
Feb 02, 2024Guru - Experienced User
Any progress on this?
KCPGS wrote:
I'm using my CBR750 as our modem and router. Netgear says that I should be able to use the parental controls, but the tile in the Orbi app doesn't show up. The Orbi is in router mode (which I understand is required). I can't figure out how to tell if it is "registered" to me, but I am able to access it through the app, so I'm assuming it is. The product is out of warranty - so no luck getting any help from Netgear.
Any help on this is appreciated.
Thanks,
Peter
