DBVicAU
Apr 10, 2021Tutor
Circle - "something went wrong"
Hi It would appear that since 2.6.2.140 firmware update on my RBR40, Circle has stopped working. I can disable it on the router and enable it via the app - it then shows as enabled on the route...
DBVicAU
Apr 10, 2021Tutor
Thanks CrimpOn. I'll head there and post the quesiton.
The forums perhaps do need to be seperated, but so far this is by far my worst technical support experience in my lifetime and I'm a certified Microsoft technical Expert with 25 years expereience in the industry across Microsoft, Citrix and VMware. If I'm finding it a poor experience, I can only imaging how non-technical customers find it. I should surely be able to pick the phone up and speak to someone - the fact that I onbly got 90 days support with the expensive device is outrageous.
Alas, it will simply mean I tell all my friends in the industry and never buy the products again. Little point me ranting as it's clearly not getting noticed by NetGear.
Thanks again for your help, CrimpOn.
Jun 11, 2021Guru - Experienced User
Try removing it from your mobile device then re-install the app.
Try installing it on a different mobile device. I saw this simiar issue with my Pad after messing around with parental controls on my RBR. After installing it on my iphone, I was able to get the app connected, then the pad started working.
