mywifi101
Dec 28, 2021Guide
Device Pause/Parental Controls not functioning
Hardware Version: RBR750 Firmware Version: V4.6.5.14_2.0.54 GUI Language Version: V3.0.1.2_2.1.30.3 Operation Mode: Router I recently discovered I am not able to pause devices or view parental...
- Jan 08, 2022
I solved my issue by factroy resetting the devices. I am able to control the devices through SPC.
If you want to save your setting take a backup and restore before activating the SPC again through the Orbi app.
I performed the reset and restore through the web interface before configuring the Orbi app.
mywifi101
Jan 08, 2022Guide
Chuckg1
Jan 24, 2022Star
I’ve done 3 factory resets in 3 weeks because the SPC stops working after a few days only. Hardcore factory reset, reinstall, resetup is not a permanent solution.
