MTNDOG
Aug 15, 2022Aspirant
"Enable Smart Parental Controls on Your Router" nag ad pops up EVERY time I login
NetGear support is clueless as how to suppress this Circle nag-ad or they are just ignoring customer satisfaction. I believer it is both! I have a case ticket open and another 30 days in which to r...
Aug 15, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Does the top of the router feel warm or extra warm to the touch when this happens?
MTNDOG wrote:
NetGear support is clueless as how to suppress this Circle nag-ad or they are just ignoring customer satisfaction. I believer it is both! I have a case ticket open and another 30 days in which to return my R7000P to Amazon for full refund. I have updated to the latest firmware version with no improvement and that Firmware Version V1.3.3.148_10.1.8 appears to have major bugs. My router randomly locks up and on reboot begins cycling through the startup routines. It recovers after several reboots.
If not solved in a couple of weeks, then back it goes to the Amazon trash bin.
- MTNDOGAug 15, 2022Aspirant2022-08-15 11:31 AM
