raavikr
Dec 15, 2023Aspirant
Enable SPC in India
How to get SPC enabled in India. I see from the Netgear site, India is not in the supported country list. Please help me to get SPC enabled in India
Dec 15, 2023Guru - Experienced User
raavikr
Thanks for an update.
But I'm not looking for general help on SPC until the feature is enabled to work in India.
- FURRYe38Dec 15, 2023Guru - Experienced User
Something to make contact with NG support about. All that is beyond forum help.
Good Luck.
- schumakuDec 15, 2023Guru - Experienced User
Nothing the community can do for you here: What countries is NETGEAR Smart Parental Controls available in? As of writing SPC is simply not supported.
