albertanon19
Mar 12, 2023Aspirant
Greyed out parental controls on Nighthawk 7000
I'm trying to set up parental controls but when I go into the router admin functions, the parental controls options are greyed out. Is there anyway to enable them? Thanks.
rich_benson
May 13, 2023Aspirant
Same issue here - with Netgear 8000 series. Been using Parental Controls for years, and had trouble with stable network connections the last few days. After disabling Parental Controls (to restore internet connectivity), the option to re-enable the feature is greyed out???
I have the premium Circle App so a refund may be in oder if they are discontinuing services...
- FURRYe38May 14, 2023Guru - Experienced User
Try using the Nighthawk mobile app connected to the router to set up Smart Parental Controls or Circle. There is a My Subscriptions menu option there I beleive under the top left menu enable that you can use to set up these features.
- rich_bensonMay 15, 2023Aspirant
The Nighthawk app did the trick, thank you FURRYe38
Parental controls re-enabled.
- FURRYe38May 15, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
