albertanon19
Mar 12, 2023Aspirant
Greyed out parental controls on Nighthawk 7000
I'm trying to set up parental controls but when I go into the router admin functions, the parental controls options are greyed out. Is there anyway to enable them? Thanks.
May 14, 2023Guru - Experienced User
Try using the Nighthawk mobile app connected to the router to set up Smart Parental Controls or Circle. There is a My Subscriptions menu option there I beleive under the top left menu enable that you can use to set up these features.
rich_benson
May 15, 2023Aspirant
The Nighthawk app did the trick, thank you FURRYe38
Parental controls re-enabled.
