AudEmms
Apr 24, 2023Aspirant
Help, my RBK 50 does not have Parental Control option at all (on app or web settings)
Hi: I have a RBK50 router (1 router with 1 satellite), but there's no parental control option available on the app or web based router settings. I subscribed Circle, still no parental control optio...
michaelkenward
Apr 24, 2023Guru - Experienced User
AudEmms wrote:
Hi:
I have a RBK50 router (1 router with 1 satellite), but there's no parental control option available on the app or web based router settings. .
Which app? iOS? Android?
Have you tried here:
NETGEAR Smart Home Parental Controls - NETGEAR Communities
- AudEmmsApr 25, 2023Aspirant
Hi, thank you for your reply.
Firmware: V2.7.4.24
Modem (connects to Netgear): Spectrum Router
Router: Netgear Orbi Router RBR50v2 (just realize it's not RBK?.. does it matter)
Have wired desktop (Window 10), android phone, Apple tablets/phones, wireless laptops at home.
- michaelkenwardApr 25, 2023Guru - Experienced User
Which one? Spectrum has supplied many different modems over the years.
Saying Spectrum is like saying "Ford" for a car.
- FURRYe38Apr 25, 2023Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
Also you might upgrade FW on the Orbi system as well:
https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/New-RBR50-RBS50-Firmware-Version-2-7-5-4/td-p/2296598/jump-to/first-unread-message
If you do, be sure to update the RBS first, then RBR lastly.RBK is just the RBR and RBS in a Kit box.
Firmware: V2.7.4.24
