checkyourmirror's avatar
May 26, 2024
How do you Deactivate Parental Controls
I'm running V7.2.6.31 on a RBRE960 and I accidentally enabled Parental Controls, and the only option I see is "Pause" but not disable. When I hit Pause, it kills my Internet and I want to Disable the...
  • FURRYe38's avatar
    May 27, 2024
    Thru the Orb app under the Security menu settings from the top left menu icon.
