Andyt650
Nov 07, 2022Tutor
How to Block new devices from connecting to Orbi (Not working)
I want to use access control to block any new devices from connecting to my Orbi Router. This was done successfully in the past via access controls so that I can block devices that changed MAC addresses that tried to circumvent time access restrictions. This used to be in the Orbi web interface in Advanced Tab, Security Menu, Access Control with option to "Block all new devices from connecting." This has now been removed from the Orbi web interface with the message that I need to use the Orbi App instead. When I use the Orbi App there is no such feature anywhere to be found. This feature was very helpful in restricting access to devices that changed their MAC address.
I did try the Armor section in the Orbi app which allows restricted access to a device, but I am not sure if this could be circumvented by changing the MAC address of that device.
Please help.
Andy
Orbi AX4200 WiFi 6 High-Performance Router (RBR750)
Latest Firmware as of 11/7/2022
- KevinLiTNETGEAR Moderator
Hello Andyt650,
Welcome to the NETGEAR Community!
You are receiving that message because SMART Parental Controls is activated on your device.
Best,
Kevin
Community Team
