Andyt650
Nov 07, 2022Tutor
How to Block new devices from connecting to Orbi (Not working)
I want to use access control to block any new devices from connecting to my Orbi Router. This was done successfully in the past via access controls so that I can block devices that changed MAC addres...
KevinLiT
Nov 18, 2022NETGEAR Moderator
Hello Andyt650 ,
Thank you for your response!
The photo you provided indicates that SMART Parental Controls is active on your router. In order to remove the SMART Parental Controls you will need to first disable it in the Orbi app by doing the following;
HAMBURGER MENU > SETTINGS > PARENTAL CONTROLS > toggle ENABLE SMART PARENTAL CONTROLS.
After the system needs to be factory reset for this change to take effect. Once the change has taken effect you will be able to access Access Controls to block new devices from connecting to your network via MAC address.
Best,
Kevin
Community Team
Andyt650
Nov 18, 2022Tutor
Hello Kevin,
For my understanding, why does resetting my router to factory settings after I toggle off Parental Smart Controls from the Orbi app work? If I toggle it off from the Orbi app, that should do it likewise from the router as well (which it isn't). I don't understand how enabling a feature on the app itself cannot be undone on the router unless it is factory reset. It seems this is a bug perhaps and not by design?
andy
