charleneram88
Sep 14, 2022Aspirant
How to set parental controls on nighthawk MS60 parent circle app and is net genie the program?
Hi, I have a nighthawk mesh wifi 6 satellite MS60, says on the list of qualified wifi routers that mine MS60 is not included, but the website: https://kb.netgear.com/29913/Setting-Parental-Control-fi...
Sep 14, 2022Guru - Experienced User
I presume you are referring to the MR60 unit which is the router portion of the MK60 series system? The MS60 is the satellite unit thus not a router nor would it have any abilities to support SPC features.
Try accessing the MR using the Nighthawk app on a phone or pad. This had the supporting features to get Armor or SPC enabled on the MR router.
