dsg88
Nov 14, 2025Tutor
I can't find the parental Controls option in the Orbi app
Hi, I'm having the same issue with my RBR350 - Orbi AX1800 WiFi 6 Dual-band Mesh Router. I can't find the parental Controls option in the Orbi app or on the router admin via web. I bought this sy...
CrimpOn
Nov 14, 2025Guru - Experienced User
Smart Parental Controls is a feature of the Orbi 'app', not the web interface. This is a screen shot of the Android Orbi app, version 2.49.0.5034:
Which version of the app do you have (Apple or Android?)
