pjd813
Aug 23, 2022Guide
I don’t need Parental Control but I cannot see where to disable it
When using the Netgear nighthawk app I went to check the Device Manager. There are multiple occurrences of my iPads and iPhones and a few other devices. The screen display in this mode looks very dif...
Aug 23, 2022Guru - Experienced User
Do you have WIFI Private IP address enabled on your Apple devices while at home? If so, disable this.
Might try a factory reset on the router and setup from scratch using a wired PC and web browser. Be sure to not enable Access Controls and Armor on the router or on the NH app.
pjd813
Aug 23, 2022Guide
I disabled the Private Wi-Fi-Adress per your response. Thanks. When I went back to the Nighthawk app on my iPad there were still three entries for it in the Device Manager. I looked at the entry for the shadow entries and they had 0.0.0.0 IP addresses and each entry had different MAC addresses. This does seem to line up with the description of how Private-WiFi-Address works. I deleted the entries that had the zero IP’s and now they haven’t come back (yet). When I use the web browser I now see only one entry per device.
I don’t seem to see Parental Controls anywhere in the web UI.
When I logged into the Nighthawk app on my iPhone for the first time in about a month there was a blue dot next to the icon for the Device Manager. When I clicked on the DM the next screen had a nag screen that was a prompt to activate/subscribe to Parental Control. I dismissed it and the next screen was not the original black screen list of devices I got in the past. It was the new white screen of a “Home” “Profile” screen with my device list. This is exactly what happened to me yesterday on my iPad. What the heck? The apple App Store says that the app was updated two weeks ago. I’ve used these apps in the past few days without issue.
I’m going to wait and see if the Private-WiFi change helps before I do brain surgery with a system reset.
