ConwayKat
Oct 11, 2023Initiate
I want to be able to use the parental controls on my netgear router
I have the orbi mesh system since 2021. Now my kids are teens and I just got them laptops. I want to be able to use the parental controls on my netgear router, but my app does not have the tile. I...
Trevmonk
Oct 11, 2023Aspirant
I struggled to get the parental control tile to show until I found the list of compatible routers here:
https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls
I was using a RBR350 which isn't on the list. When I upgraded to a RBR750 router (but keeping the old satellites which were compatible). the tile did appear. From your profile it looks as though you have the RBR860 which is also not on the list of compatible routers, which may be the problem.
ConwayKat
Oct 12, 2023Initiate
My router says orbi router rbr850 on the bottom. Not sure why my account says otherwise. Maybe the inaccurate listing is my problem?
When I look at the page where it has all the routers that have parental controls, both rbr850 & rbr860 are listed.
- TrevmonkOct 13, 2023AspirantI was given the same advice as you by Netgear support which includes the clause:
"The NETGEAR SSO account that you use to log in to the Orbi app is the same account that your router is registered to"
If you have a different device registered to your account that may be the problem.
