niallg
Dec 30, 2022Aspirant
MR60 Parental Controls not working
I signed up for free trial of Parental Controls. None of the features work. In addition access control through the app no longer works since I activated the parental controls. Does anyone know how to ...
niallg
Jan 04, 2023Aspirant
Thanks for your suggestion. I already tried that. Access control does not work beyond version 122. I opened a ticket for that and spent hours on the phone with Netgear to provide logs etc. It was never resolved. I just want to get back to where I was before I activated Parental Control with access control working. I guess worst case I can start over with a new account. Or perhaps when the trial times out it may start working again as before.
Jan 04, 2023Guru - Experienced User
After loading newer FW, did you factory reset the MR and setup from scratch using the NH app then see if SPC is enabled then?
- niallgJan 04, 2023Aspirant
Yes. I did a factory reset and a setup from scratch.
- FURRYe38Jan 04, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.- niallgJan 04, 2023Aspirant
I have a dual WAN setup. Arris NVG443 (Frontier) plus unknown fixed wireless receiver (Surfnet) feeding a Peplink Balance 20 connected to the MR60. All CAT6 cables. Same setup I had. Only thing I changed was to enable the Parental Controls.
