Tiffjohns22
May 27, 2024Aspirant
MR60 parental controls
I have paid gor for the parental controls subscription. It worked "ok" for a while, then just quit well over a month ago. I have logged out, logged in, rebooted multiple times, Uninstalled, and reinst...
May 28, 2024Guru - Experienced User
Be sure the NH mobile app is up to date.
Be sure FW on the MR and MS is up to date. Update the MS first, the MR lastly.
Try a factory reset and setup from scratch on the MR60.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Submit a bug report thru the NH app:
- Tiffjohns22May 30, 2024AspirantI have been unable to fix this using these steps. I don't think I can survive summer without the ability to play/pause🤣
- FURRYe38Jun 04, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
