lifer70's avatar
lifer70
MR60 Sattelite will not reset
One of my Nighthawk mesh WiFi 6 MR60 routers has a steady flashing light. I cannot reset it or change the flashing light. The other Sattelite is working fine.
    • plemans's avatar
      If you hardwire it into the router, are you able to see/access it?
      Also, when its hardwired, check the firmware version its on.
      What version is on the router?
      and on the satellite?
  • I had the same problem on 2/12/22. I had to do a firmwear update to get the MR60 working again. Fortunately, it was still under warranty and I was able to get assistance from Netgear tech support. I don't think I could have done it without support.
