Laurent78
Oct 06, 2021Aspirant
My IPV6 configuration breaks SPC
My configuration is the following: - the modem/router FTTH provided by my ISP. The IP adress is dynamic. - my RAX10 router behind the ISP router. All my family devices are connected to the RAX10. I...
Oct 08, 2021Guru - Experienced User
What mode is the ISP modem router working in? IF in router mode, and you have the RAX in router mode, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
Possible that SPC may not be supportive of IPv6 configurations as well. Something to ask NG support about.
- Laurent78Oct 09, 2021AspirantYes, I did your option 2.
My guess is that the “pass through “ option for ipv6 is also going through parental control.
I don’t know how to set up ipv6 better (all my tries with other options failed). I asked the customer support some help. Still waiting.- FURRYe38Oct 10, 2021Guru - Experienced User
Keep on them then.
Good Luck.
