Laurent78
Oct 06, 2021Aspirant
My IPV6 configuration breaks SPC
My configuration is the following: - the modem/router FTTH provided by my ISP. The IP adress is dynamic. - my RAX10 router behind the ISP router. All my family devices are connected to the RAX10. I...
Laurent78
Oct 09, 2021Aspirant
Yes, I did your option 2.
My guess is that the “pass through “ option for ipv6 is also going through parental control.
I don’t know how to set up ipv6 better (all my tries with other options failed). I asked the customer support some help. Still waiting.
Oct 10, 2021Guru - Experienced User
Keep on them then.
Good Luck.
