CJK440
Aug 25, 2021Tutor
Netgear Smart Parental Controls don't block google search results (web and images)
Long story short, I just purchased a subscription to Netgear smart parent controls and found that it does not block explicit results from google. Regular web results with explicit language still pop ...
- Nov 23, 2021
I know time has passed but ultimately a factory reset did the trick.
IDraper
Oct 04, 2021Tutor
I got SPC working with the Nighthawk and am able to monitor the kids as advertised.
However there ways to bypass the controls from the IPAD however I get an alert when this happens.
As recommended, it needs to be a partnership with the Child so they know why we are wanting to put limits and protection so that we get their full cooperation and they learn to have some self control.
Another thing to look at is modifying the DNS to something like OPENDNS which allows you to block sites by category and specific sites.
This will not capture google image searchs, but prevents users from going directly to the sites where the images came from.
Appart from this I suggest cultivate a great relationship with your kids and above all pray. :-)
ellen2298
Oct 04, 2021Apprentice
Glad it is still working for you. Sadly I am nowhere and the most basic functionality of usage and history isn't even working let alone any filtering, bedtimes etc. After being transferred twice and on hold for more than 2 hours I had to get off the phone last night. I am going to try again today but if no luck I guess I will have to cancel the subscription and go a different route. Are you aware of any way to get to advanced support to be able to help someone with an issue like mine?
- FURRYe38Oct 04, 2021Guru - Experienced User
- CJK440Nov 23, 2021Tutor
- FURRYe38Nov 30, 2021Guru - Experienced User
Enjoy. 📡
