Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 with SPC
For all you Orbi AX 7 series users, Smart Parental Controls are now available: https://community.netgear.com/t5/Orbi-AX/New-RBK752-753-Firmware-Version-4-6-3-7-Released/m-p/2115667/highlight/true#M1...
- Jul 14, 2021
Confirming successful access to SPC via the app.
Per Christian_R's instructions, I had to remove and reinstall the app for Parental settings to become visible.
Christian_R wrote:Hello Community!
I've linked an article below on how to setup/install NETGEAR Smart Parental Controls. Feel free to let me know if you have any questions! If you're unable to see the option in the Orbi app, may you reinstall the Orbi app and let me know if your issue persists.
sharmy
Jul 12, 2021Apprentice
Great to see this has finally been added.
Now for the important stuff... how does one access these settings? I must be missing something!
- FURRYe38Jul 12, 2021Guru - Experienced User
Did you install the FW and reset and setup from scratch?
I haven't seen the UI as i don't have the 7 series Orbi.
Look under the Basic Tab for Parental Controls menu option?
Or Try under Advanced Tab/Security?
There maybe a Upgrade to Netgear SPC button seen here?
sharmy wrote:Great to see this has finally been added.
