Anne367
Oct 31, 2024Follower
Nighthawk AX6 AX5400 Parental Controls Premium Subscription
I have the 1 year parental controls premium subscription. It worked great for the first 6 months but now everytime I want to access it, it asks me to setup up parental controls. When I do that it g...
Nov 01, 2024Guru - Experienced User
What RAX### model router do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
