tsebra
Aug 20, 2021Aspirant
Nighthawk MR 60 Mesh
I have been immensely disapointed with the way devices connect to this system. Practically ruined my sonos setup and have to put a router next to and hard wire each speaker or it will not work. Now i...
tsebra
plemans thanks for the response. I am now having issues with a HP Laser pro printer. The printer will connect to the wifi network but our computers will not print to it as it says the printer is unavailable. Its the same issue I have with sonos you could not see the speaker was connected. My iphone will print to it but my macbook wiill not nor will any PC in the whole house. On the same network but it must be a mesh system as likely each device is hooked to a different mesh router. I do blame the router as there was nothing anywhere in researching this device on forums and elsewhere to suggest a user would potentially have issues with every other device linked to the network. Any suggestions are welcome i am not excited about adding another $129 sateliite add on router just to run a printer that should print wirelessly without effort
Aug 20, 2021Guru - Experienced User
What modem/gateway is the mesh system connected to?
What firmware is on the router?
How big is your home?
What materials are your home made from?
If you power off the sonos system, do you have issues with other devices?
