marythecherry
Jan 18, 2023Aspirant
Nighthawk parental controls
Hello, my parents recently bought a Nighthawk AX5400 router, they're about to get the Netgear app (parental controls) to look at my search history and logs, which I'm fine with I'll just make sure I ...
jennymartein
log in to your router, as you would to change your network name and password. Once you've logged in, look for an option for parental controls or access restrictions. Not all routers have these options, and the location of these options can vary depending on the router you're using.
