Mikethecherry
Mar 21, 2023Aspirant
Nighthawk parental controls
Hello, my parents recently bought a Nighthawk router, they're about to get the Netgear app (parental controls) to look at my search history and logs, which I'm fine with I'll just make sure I won't l...
Mar 21, 2023Guru - Experienced User
They can't see the old stuff.
But if its something is bothering you that much, much have a talk with them.
Certain things are healthy if done properly or in the proper context.
- MikethecherryApr 09, 2023Aspirant
Are You Sure They Can't See The Old Stuff? How Do You Know?
- plemansApr 10, 2023Guru - Experienced User
If you're really that worried about it, accidentally reset the router.
but again, having a healthy conversation with them about it is the key.
