Nnenna
Mar 07, 2024Aspirant
Nighthawk time is stuck
All the history is writing out for Tuesday at 6:23pm - almost 2 days ago. Also the parent controls are not applying. Was there a bad firmware update recently?
- Mar 19, 2024The reboot sequence suggested did not fix it. I ended up cancelling parent controls, factory reset, and then enabling parent controls. Got back full functionality after that.
Mar 12, 2024Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Nnenna
Mar 19, 2024Aspirant
- FURRYe38Mar 21, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
