Nnenna
Mar 07, 2024Aspirant
Nighthawk time is stuck
All the history is writing out for Tuesday at 6:23pm - almost 2 days ago. Also the parent controls are not applying. Was there a bad firmware update recently?
- Mar 19, 2024The reboot sequence suggested did not fix it. I ended up cancelling parent controls, factory reset, and then enabling parent controls. Got back full functionality after that.
Nnenna
Mar 19, 2024Aspirant
Mar 21, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
