Miguel20
Aug 20, 2021Aspirant
No Parental Control RBR50 V2.7.3.22
Orbi firmware auto updated to v2.7.3.22 and there are no parental controls now and Circle no longer can connect. I reverted to V2.6.1.40 and the functionality comes back. Then a few hours later (or o...
- Aug 24, 2021
Whats listed under Basic Tab?
SPC will be seen under the Basic tab if and when it shows up.You might try this on this version of FW:
I had to do this once after accidently selecting the upgrade to SPC button incorrectly.
Aug 20, 2021Guru - Experienced User
