Miguel20
Aug 20, 2021Aspirant
No Parental Control RBR50 V2.7.3.22
Orbi firmware auto updated to v2.7.3.22 and there are no parental controls now and Circle no longer can connect. I reverted to V2.6.1.40 and the functionality comes back. Then a few hours later (or o...
- Aug 24, 2021
Whats listed under Basic Tab?
SPC will be seen under the Basic tab if and when it shows up.You might try this on this version of FW:
I had to do this once after accidently selecting the upgrade to SPC button incorrectly.
m_mirakhor
Sep 04, 2021Aspirant
My router automatically updated to version 2.7.3.22, at the time i had circle for Disney enabled and it carried over with the upgrade, i was on the app one day and it asked if i wanted to go over to Smart parental control which i did and it worked fine, up until today when for some reason i have been having network issues so i figured i would factory reset the orbi as i haven’t done so in a while.
After the reset had completed and proceeded to set up the orbi via the mobile app but for some reason the parental option did not appear i logged into the orbi via the web portal it also was not there. As i was trying to figure out what went wrong it "magically" appeared on the phone app, took about 30 min however it hasn’t appeared on the web portal which doesn’t bother me because it works
Sep 04, 2021Guru - Experienced User
I believe NG maybe removing the SPC from the RBRs web page and only having it appear on the Orbi app as most of the configuration is done thru the Orbi app.
