johnh81
Dec 13, 2021Tutor
No time total for day and no usage history after purchasing parental controls
Parental controls were working as expected from the time I purchased the Orbi until the parent control trial ended. I purchased the year subscription but from that time the two profiles I have under parent controls no longer show any time being used each day and no usage history. I almost want to say bait and switch but there must be a technical reason why this stopped working once it was purchased. Any ideas?
- Dmink99AspirantThe controls was working for me during the entire trial, and shortly after but past month or so it's been nothing, no stats, time tracking or anything, just stopped. I can still pause manually for each profile but that's it.
I've had similar issues with my Orbi RBR850. I'm nearing the end of my one month trial and for a second time the parental controls have stopped working: no tracking of time, no filtering and no ability to pause devices. It first happened after about a week and deleting and recreating the users fixed it. It's stopped working again. I'm thinking to reboot the device and see if it resumes tracking and filtering.
Any ideas besides factory reset and setting up again? If I do a factory reset, what's to guarantee it won't happen again after a week or two?
I'm on V4.6.3.16_2.0.51. That looks like the latest after checking for updates just now.
- johnh81Tutor
I was close to having to do a factory reset but some combination of re-installing the iOS app, removing, and re-adding the child accounts, and rebooting all the Orbis seemed to have gotten this working again for me. Been solid for a couple weeks now.
I went through 3 cycles of factory resets to make SPC work. After reintalling and redoing all the profiles, I get at best 48-72 hours of parental control then it stops tracking usage and history without warning. I also noticed the devices online is highly inaccurate. This product is garbage , what are the alternatives?
