robinhood_na
Oct 15, 2024Aspirant
Orbi -RBR 750 - Access controls no longer available
Hello, I had setup Access controls a few months back to "not allow new devices to connect to the network". Recently I enabled parental controls through the Orbi App. The Access controls page ...
michaelkenward
Oct 16, 2024Guru - Experienced User
robinhood_na wrote:
Recently I enabled parental controls through the Orbi App. The Access controls page just displays a message stating that i need to access it via the Orbi App.
Where are you looking on the router? Maybe it has moved in new firmware. Here it is buried in Attached Devices:
Then:
The Orbi App does not have this option.
Again, is it buried in Device Manager in the app?
I am using different hardware, but these things are usually common.
If you are looking for a global setting , then the App doesn't appear to support that.
Just another user with time on their hands.
robinhood_na
Oct 16, 2024Aspirant
Hello Michael,
Thank you for your response.
The Access controls page was under the Security -> Access Controls (Advanced Tab). I've also looked on the Attached Devices page, but it does not exist there.
On the Orbi App, it is no were to be found. The Access Controls option was never there on the App.
Support stated the only option they can thin of is doing a reset to factory settings, which i will probably end up doing this weekend. But I'm going to continue to look for anyone that may have resolved this in other ways.
Thanks Again!
- FURRYe38Oct 17, 2024Guru - Experienced User
If Smart Parental controls were ever enabled thru the Orbi app, then Access Controls is removed from the WEB UI as SPC takes over thru Orbi app. Would probably need to factory reset the RBR and setup from scratch with a wired PC and web browser, don't use Orbi app or enable SPC.
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Then Access Controls should re-appear on the RBRs web page.
What FW version is loaded on the system?
robinhood_na wrote:
Hello Michael,
Thanks Again!
