wmdmoyer's avatar
May 10, 2025
Orbi Adult Content Filter not Workin
The orbi (RBE770) parental controls are not blocking adult websites.  I've verified that there is no VPN enabled and tried from both iphone and laptop.
additionally, VPN tomy work network no longer works and I occasionally can't get an https connection to some sites, such as nytimes.com
I'm wondering if my router was hacked.   Any thoughts?
Bill
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046
    Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
