RFulton
Jul 11, 2023Follower
Orbi AX4200 Prevent IP from counting aginst internet usage
The issue I have is that I setup separate profiles for my kids. I set time usage on the profiles to help them understand how to limit the time they spend online. The issue I am finding is that my dau...
Jul 11, 2023Guru - Experienced User
Not much we can do with wifi devices that call home checking there support data. You might check with the mfr to see if they have any information regarding how to maybe disable there system for checking so much or if you can manually have the device check for updates.
