wvkregten
Jan 23, 2023Luminary
ORBI Mesh RBR760 CPU Usage due to Parental Controls
Hello, When I activate my subscribed and paid for Parental Controls the CPU of the RBR760 goes up to 90 to 100% CPU usage constantly and never returns to normal values. When I switch it of...
wvkregten
Jan 31, 2023Luminary
Monitoring today I see these steady values. Is this too high or normal / acceptable?
Jan 31, 2023Guru - Experienced User
Over all seems kinda high for average or normal CPU usage.
Something NG will have to review.
FYI, please edit out any MAC addresses or product serial numbers from pictures before posting in public forums for security reasons.
- wvkregtenFeb 06, 2023Luminary
Ok. so I full pin reset the router and the satelites. After settig up again using a webbrowser on a wired pc the CPU usage is around 20% with Armor and SPC disabled. When I enable Armor it is about 25%. When i enable SPC it again jumps to 80+% on both cores.
At that moment I have 2 profiles setup in SPC but no devices in it yet. I do not want to add devices since the CPU load is too high and it will not work.
Any help?
Better I ask a refund 🙂 for wasting money on Armor and SPC (100us$)
How to send, Netgear gives only 60 day warranty.
- FURRYe38Feb 06, 2023Guru - Experienced User
That too. Something to ask them about. They need to look into this.
Good Luck.
Yeah, sounds great. How do I contact them or log support case? Have you experienced their support website? It does not work.
- wvkregtenFeb 14, 2023Luminary
I replied. Any news or update? I disabled Armor as well as it also takes 20% CPU doing not much 😞
