wvkregten
Jan 23, 2023Luminary
ORBI Mesh RBR760 CPU Usage due to Parental Controls
Hello, When I activate my subscribed and paid for Parental Controls the CPU of the RBR760 goes up to 90 to 100% CPU usage constantly and never returns to normal values. When I switch it of...
wvkregten
Feb 06, 2023Luminary
Ok. so I full pin reset the router and the satelites. After settig up again using a webbrowser on a wired pc the CPU usage is around 20% with Armor and SPC disabled. When I enable Armor it is about 25%. When i enable SPC it again jumps to 80+% on both cores.
At that moment I have 2 profiles setup in SPC but no devices in it yet. I do not want to add devices since the CPU load is too high and it will not work.
Any help?
Feb 06, 2023Guru - Experienced User
NG will need to review this and take a look. You might capture debug logs with out SPC enabled then with SPC enabled. Lets get them to NG.
- wvkregtenFeb 06, 2023Luminary
Better I ask a refund 🙂 for wasting money on Armor and SPC (100us$)
How to send, Netgear gives only 60 day warranty.
- FURRYe38Feb 06, 2023Guru - Experienced User
That too. Something to ask them about. They need to look into this.
Good Luck.
Yeah, sounds great. How do I contact them or log support case? Have you experienced their support website? It does not work.
- wvkregtenFeb 14, 2023Luminary
I replied. Any news or update? I disabled Armor as well as it also takes 20% CPU doing not much 😞
