Emmylou083
Aug 02, 2021Guide
Orbi parental controls
I get an error when trying to toggle off ore tal controls (unable to toggle state SPC-DISABLE-FAIL) and also when I attempt to add a device to a profile. I want SPC on but was trying to troubleshoo...
Aug 03, 2021Guru - Experienced User
- Emmylou083Aug 03, 2021Guide
Firmware version: V2.7.3.22
Does a factory reset unwind all of the firmware updates? I had to do several manual updates to get to recent firmware versions, so just curious. I have not performed a factory reset since all of those updates several months ago.
- FURRYe38Aug 03, 2021Guru - Experienced User
No. Just clears out configurations and any lingering old FW code.
ok perfect, thanks! I'll have to find some downtime for everyone (any myself with WFH) to give that a try.
